Fuse Location Need To Know... - Audio & Electronics Forum
Wednesday, October 04, 2006 7:19 PM
Hey i need to know if there is a fuse for your front turn signals in a 98 sunfire gt, if there is plz tell me where they are located, thank u
Re: Fuse Location Need To Know...
Wednesday, October 04, 2006 7:29 PM
stop double posting!
The fuses should be on the inside of your drive side dash. I think there is only a fuse for all your turn signals. Are they not working or flashing fast, if they are flashing fast you have a burnt out bulb.
Wednesday, October 04, 2006 7:43 PM
yeah... i changed the bulb and it didnt fix the problem... my left indicater is clickin reallly face on the cluster, and the driver front signal is not flashin, its solid when the headlights are on, but wont flash when i turn left, the rear signal is just flashin fast, i changed the bulb with the rright size and still didnt work
Thursday, October 05, 2006 1:17 AM
check and make sure just one of the filaments in the bulb isn't broken, and check to make sure you used the right bulb. Otherwise, there's a short/break in one of the three wires to the bulb. I forget which one does the blinkers, but a hayne's manual can tell you that.
Wednesday, October 11, 2006 1:37 PM
I'm having the same problem ryt now..lol..I was about to get up and go see what was the problem with that. I'll tell you if I can find something.
