15 in lcd questions - Audio & Electronics Forum
15 in lcd questions
Sunday, September 03, 2006 6:45 AM
I got 2 question first can i use a house 15 in LCD in my whip and if i cant were can i find a 15 in lcd to use\
thanks
Re: 15 in lcd questions
Monday, September 04, 2006 8:47 PM
would lo0k ridiculous in the dash,could do a 15'' flip down in backseat,trunk or beauty panel on ur trunk.....unless u know what ur doin i wouldnt make it ur 1st fiberglass project....
Tuesday, September 05, 2006 9:39 PM
lol thanks for posting back its not realy my first glassing but idk go look at wat i got so far and tell me wat u think of it in the middle of the subs i got
Wednesday, September 06, 2006 7:57 AM
You can fit it in, but you are going to need a video source, like a DVD or VHS player, or PS2 or XBox. You will also need a power inverted matched to your TV. Look how many watts the TV uses (usually on a sticker on the back or in the manual) and get one rated higher. I personally suggest you hardwire the power inverter if you plan on keeping it in the car all the time. Make sure you get one for your DVD/XBox/PS2 ect or add the watts together on the TV and source, and get one that is rated higher then both.
If for some reason you need to extend the wire on the TV itself, you can cut it open. There will be three wires, make sure you cut one at the time and extend it, solder(for the best connection) and tape it back up. (Or you can buy an extention cord, but I can see problems running that in a car, also not the safest in a vehicle)
Let me know if you have any more questions!
Sam
Ban low-performance cars, not high-performance ones.
Wednesday, September 06, 2006 3:25 PM
u wont necesarily need a power inverter u can find 15'' flip downs that are cheaper than a 15'' lcd tv,i got mine for $229.99 its a planet audio i just had remove te flip down portion and hinges,disconnect the circuit board for the dash lights and run a new wire for the power source/ground and rem wire......
