NEED HELP FINDING SPEEDOMETER WIRE BEHIND DASH - Audio & Electronics Forum
Tuesday, August 29, 2006 8:21 AM
my speedometer is messed up on my 97 sunfire coupe. so im installing a greddy auto timer with built in speedo, ect... i have everything hooked up correct. but i cant seem to find which wire is the speedo wire. any know?
Re: NEED HELP FINDING SPEEDOMETER WIRE BEHIND DASH
Thursday, August 31, 2006 12:40 AM
i dont know but look on the tranny the vss sensor maybe its atleast the same color
Saturday, September 02, 2006 2:43 AM
there isn't a specific speedo wire in the dash. all the information for the gauges and idiot lights is sent via a serial bus.
to get a speed signal, you will need to go to the transmission.
Saturday, September 02, 2006 5:42 AM
If you have your cluster out , the plug the connects to the back side should have 17 (if I recall) wires. You're looking for the Drk Gr / White stripe , vehicle speed input. Tap into that one.
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
Saturday, September 02, 2006 5:55 AM
PoundinFire is incorrect.
john317(AKA Gary the Old guy) is perfectly correct.
The same dk. green w/white wire also goes to the radio connectors.
sig not found
