ok so where the fuse for these bulbs??? i got stopped because my license plate light was not on. when i checked them today water poured out of the hole where the bulb socket goes into. ok so the bulb where cracked and stuff...very oxidized. i bought new bulbs, the bulb gel and put the new bulbs in. when i turn my headlights on it still does not turn on. the pontiac wording on the trunk panel does not light up which is the same light that shows the license plate at night. someone give me some help with this...im stuck.
"Sunfire got stolen, all i have is the J to remember it by"
Check the new bulbs, check the wires, pull off your fuse box door and read it. There should be labes on it telling you what fuse does what.
They work on the same concept as your DRL's. They will only work w/ the key in run. Try that and see if they turn on.
oh ok
i will check later on thanks, man i thought that could have been it...argh is always the simpler things
