ok well i got the back seat down, i removed the 4 plastic rivet things, now what? do i have to remove those panels on the side? I dont know how to do that if im supposed to. pics would help oodles. i did search this, but i didn't understand the other post.
bah nvm ill just buy new 6x9's when i go to buy a system next month, these speakers arn't that great lol.
go to www.teamforwardmotion.com
click on jbody tech
click on audio
there should be pics and step by step instructions.
GO PATS!!!
actually its really easy just tug on one side a little bit and it should come out then the other side will slide out ... you dont need to take and side paneling off at all.
once the speakers are out, leave em out
I just bought a 20 inch widescreen ultrasharp flat pannel..I'm going to have to subscribe to the high quality porn places now......damn
easiest way to remove the rear deck cover is as follows.
1) Lower your rear seat.
2) Remove the plastic plugs, on my fire there are 2, some cars have 4.
3) Pull rear upper trim off, Its not needed, but it makes some people have an easier time.
4) Now pull the rear deck piece a little out and up, you will see how your seatbelts are in the way. At the bottom om the slot where the seatbelts are is a slit, so you move the seatbelt through that slit.
5) Now pull on the deck, up and out.
(ps) If you have a sunfire, you may have the child saftey belt clips in the rear deck. Just pull the carpeted piece above that and it will come right out.
ok well little problem
i did the first few steps, up to where i take the seatbelts out through the little slit, but its stuck still, i tried pulling a bit but it wont budge, its like stuck under the side panels or something, heres a pic i took.
ok well i got it off kinda, its only stuck at the left rear somewhere, i cant get it off no matter how much i pull, any tips?
get in the trunk, unhook the speaker wires, then get back to the rear seat, lift it up as much as u can to get ur hands under it, the speakers are held in with a couple clips, push the clips and lift the speakers out, theyre not that deep, thats how i did mine when i first removed em
ok cool that worked perfectly, ty.
i was gonna say pull harder.....
