Hey guys, I just finished a box and I had to use a BALOON to hold the ring in place because the dowls wouldn't hold the ring in place.
Does anyone know a better way to hold the rings? No hot glue, please
whats there to elaborate? lol put a screw in the dowel/MDF ring....might be a bitch to get it to start in the dowel though
ive always used hot glue, is that what wouldnt hold it for u?
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
if you can get the black hot glue, that seems to work for me, or use mdf for legs. you can use a jigsaw to get the angles so that it screws flat on your board. remember though, predrill going into the tops of both, if you go into the grain of mdf, it will split.
use a 2 x 4!
why the hell are you using dowels anyway...they are fragile and flimsy, lol. Just cut a piece of 2x4 and screw the ring to it. then screw the 2x4 to the base from the backside.
Do your glass
When it's all hard, unscrew the screws and cut your ring out.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
