i have 2 kenwood excelon kac-x1202dvc.
theres the specs. i built the boxes at 2 cubes a piece. the subs are going to be inverted. each in their own box. id like it tuned around 32 htz. how long should the port be to be tuned to 32htz
thanks
M62 KIT for sale PM ME
With those box dimensions and a 3" round port.... 9.5" will tune it @32hz
They have it tuned @ 41 with a 5" port.
RE Audio
is it just me or does it seem like the 1st 2 subs on that list have really low sensitivity....82 and 79?...sounds brutal....
LOL
them subs are brutal. ive heard both of them. what is it tuned at say with a 7" long port?
had a comp this past weekend. definatly a new box getting built. only hit 141.3 anoither vehicle with the same gear hit 144.8 so there something seriously wrong goin on.
Go with something around 4 cubic feet.....with 60-80 sq.in. of port tuned @ around 40hz. It wont be very musical...but it'll be louder. The tiny 3" ports is whats killing you....but then again they only have 6.4mm of x-max. With that siad I'm suprised you hit 140 at all.
If you give me the max dimesions youre looking to use I can design something for you. How did you have the box facing when you got metered?
RE Audio
i had the box facing intowards the cabin. but im completly redoing my trunk/backseat this week so any new designs are welcomed.
i would like to use as much of the trunk as possible
will you do this for any1....
I would like a setup using two tens....facing out into the backseats...filling the whole that leads into the trunk when the rear seats are down.....
I can figure out a box....but you have to make trim pieces yourself for around it to seal the trunk off from the rest of the car or else it will sound like poo. Just give me the max width and height of the opening that the box will be able to slide into.
RE Audio
total blackout wrote:i had the box facing intowards the cabin. but im completly redoing my trunk/backseat this week so any new designs are welcomed.
if you had it facinf towards the cabin...you HVAE to have the baffle (face of box where the subs are mounted) sealed off from the trunk. if you dont....you can and probably will get cancelation which will hurt your score. You'd probably be better off facing it into the trunk with the way you had it.
RE Audio
max would be 16"x35" outside
