What size wire do I need? - Audio & Electronics Forum
Monday, May 15, 2006 12:33 PM
I'm acquiring a 2002 cavalier, and I'm going to put my system that was in my Trans Am in it.. thing is I'm adding an extra amp that I didn't have a chance to put in before.
I'm going to be running an 800W amp for the subs, and a 720W 4 channel for the speakers, what size wire do I need to run from the batt for this? Guy at the stereo shop said 4 gauge but that seems kinda small? I figure I'll run a beefy wire to the trunk then split it via a junction block, but just wondering what size to run?
PS. It looks like putting in a headunit in a 2002 cav is a pita, way to go GM
There will always be someone faster than you, but thousands slower and dumber than you.
Re: What size wire do I need?
Monday, May 15, 2006 12:46 PM
4awg will work fine. but go bigger if you want, won't hurt anything.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Monday, May 15, 2006 12:50 PM
I would say either run a 4ga for each amp from a distribution block that connects at the battery or run 0ga from the battery bach and then do 4ga from a distribution block. I tend to go a little bigger. Like my MTX amp requires 8ga, but I run 4ga instead.
yea run 1/0 ga back to a block and use 4ga from there, ull be fine
Alright thanks a lot, guess I'll just run 4 then since I have some sitting around.
Monday, May 15, 2006 1:01 PM
Wow, you guys respond quick, haha, in the time it took me to post that 2nd msg you guys had also posted! Ok, I'll see how much wire will cost for a thicker ga... hmm... I'm guessing I should also get a yellow optima top and upgrade all my other wires too, haha. Thanks for the help guys.
Monday, May 15, 2006 6:54 PM
dirty elf wrote:yea run 1/0 ga back to a block and use 4ga from there, ull be fine
Yea. Do it right and go with 0 guage now. That way, your covered if you decide to upgrade in the future. Plus goin bigger never hurt.
Wide Body Progress
