ok guys a freind of mine made this box for me i want to put my subs like there pictured but im not sure how to wire them i have a kicker kx1200.1 1ohm stable amp and the subs are dual 4ohm how do i need to wire them up for them to work right like the way they are
http://www.geocities.com/WIJTuners/?200511
wi jbody site
http://www.cwctekcom.com/ go here for some awsome deals on installs and awsome stereo stuff in new lisbon, WI
wi jbody site
that wont work couse the subs will cancel eatch other out couse one sub is in and the other is out
wi jbody site
It'll still play like that but maybe you could try this if you want then to work how you want..
I think that'll work, but I wouldn't try it until somebody else chimes in.
-Seth
robert jones wrote:that wont work couse the subs will cancel eatch other out couse one sub is in and the other is out
To fix that, run one of the speakers 180 degrees out-of-phase. Meaning...wire one of them up + to+, - to- and the other one + to - and - to +. So when one is pushing in, the other one is pushing out. This will compensate for the box.
Sam
Ban low-performance cars, not high-performance ones.
Which is exactly what wizkiddrummer said. Make sure to run the subs in parallel.
Sam
so when you say parelel switch the positive and negative on one fo the subs right
wi jbody site
NO, that is 2 seperate ideas. Look at the last picture, see how the positive off one VC goes to the negative of the other VC? That will run the speakers out-of-phase and will work w. the box you have.
Parallel is how you wire the speakers. Just follow the picture!
Sam
aight ill try ythe seconds pic then ill let you no if it works i belive you guys that it will
wi jbody site
That box looks mighty small for those subs.
yea i no but its just a temp my freind spent so mutch time and moneyu in it and he gave it to me so i have to put it in my car for at least a bit.
wi jbody site
