ignited ignition - Audio & Electronics Forum
ignited ignition
Friday, April 28, 2006 5:34 AM
hows it going, i just bought a push button start from ignited and i was wondering if anyone on here had bought one and put it on and had like a wiring diagram or anything to help out with the install. thanks
Re: ignited ignition
Friday, April 28, 2006 9:17 PM
well you didnt search.
but since I am feeling in a good mood( ie bored) I help you out.
ok what you dont realize (dont worry they got me to) you just bought a toggle switch about 3 dollars in parts. basiclly your going to bypass the turning of the key bye sending a 12v to your starter. look under the plastic peice behind the wheel, you want to find a yellow wire. now when you push the button in it will send the signal to the yellow wire and wallaw there you have it. also your going to have to push it in as long as you would turn the key. good luck
BTW pm if you have any Q's
"boobs now with Riboflabin"
Friday, April 28, 2006 10:42 PM
FIrst off, which car is it going into in your profile? I have a 97 w. the ignited one, e-mail me if you want: atroxaranea@hotmail.com
Basically, it is a switch, but the wiring is more complex then just hooking it up to your starter wire.
Our cars have something called Passlock, which if you just sent a signal to the starter, it would stall out everytime. You will need a bypass module and a few relays.
Sam
Ban low-performance cars, not high-performance ones.
Saturday, April 29, 2006 11:40 PM
ummm unless you have the key in the igniton.
Sunday, April 30, 2006 5:18 AM
Funny, my car still stalls out. Right now, its hooked up to the (-) start wire on my alarm.
Sam
Monday, May 15, 2006 11:57 AM
well i was testing everything today, and i used a volt meter and the yellow wire coming off where you put the key in and turn goes for 5 volts all the time to 3 when you put the key in the on position, i dont know if im doing something wrong or what but i wanna make sure i am using the right wire before i do anything, the only 3 wirescoming off it of are light yellow, black and white, so can someone please clear this up for me
Monday, May 15, 2006 8:44 PM
anyone know if that is the right one or not
Tuesday, May 16, 2006 7:26 AM
Jcavi wrote:ummm unless you have the key in the igniton.
Correct,
Which you need anyways so YOUR STEERING WHEEL WORKS! lol....
Tuesday, May 16, 2006 7:46 AM
Bah! Who needs to steer?
__________________________________________________________________
Performance cars do not win car shows and show cars do not win races.
It's up to you to decide which you'd rather win.
