i installed my subwoofers today, and i got a small problem...... when i plays music my bass cuts in and out, like it will go for so long then it will cut out for abit then it will keep going, theres nothing lose i check that. the box i have is a sealed box.... could that be the problem? do i need to vent the box? any help will be great thanks!!
You don't NEED to vent the box, it is not your problem...Is your amp staying on all the time? Check the LED that is on the amp while playing music and if it turns on and off there is either a REM problem or else your battery to amp is coming loose somewhere or shorting out (you have an inline fuse though, right?) ... or it could be a bad ground.... if it's not any of those, I don't have a clue, unless its an internal problem with the deck you're running, which i doubt.
LOL
if the amp is only 4 ohm stable and u wire it below that. it could cause the problems described.
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
i got 2 12 inch kicker cvrs and a 600.1mono amp... the light does come off when the bass gets really loud... so i hope that helps! gold digger is loud........... lol
check your connection at the tinsel leads on your subs. that could be shorting when the bass hits hard. tape em up or heat shrink em.
Sounds like you are overloading the amp. Back off on the gain/s or turn the bass down some.
you snooze you lose!
keep working, millions on welfare depend on you!
revvvin87 wrote:Sounds like you are overloading the amp. Back off on the gain/s or turn the bass down some.
i think thats what im doing wrong........ but ill check my ground too.... but i think i got the amp turned up to loud...
ur gain isnt a volume knob, if you wanna know how to do it right, read lanmans sticky at the top of the page
LOL
i know my gain isn't a volume knob.......... so bite me.....
is your amp bridged if so connect it the regular way
