Does anyone have a schematic for the Fog Light switch for z24's? There are 3 pins on the switch. I need to know if it throws power or ground, and which is the illumination lead's power or ground. I was emailed a picture which showed switch plus stock wiring, that's not what was shipped.... 3rd time I bought something from classifieds and the seller wasn't completely honest.
^CLICK ME TO SEE HOW I BUILT EVERYTHING^ How To in Interior Forum
I will give it a looksiewhen I get home, Im at work and dont have the magic FSM, I am going to make the guess everything from 95 to 2004 is the same since i have a 97 book
i got it for free from a member here, whats your email ill send you the GM schematic. if you can figure out how to use a stock switch with aftermarket lights (obviously with a relay or two) let me know!!!
this useless post brought to you by the alcoholic known as LUNDiS
I think I can handle it
mennitti@pennswoods.net
Thanks.
FOg lamp switch has 3 leads coming off of it.
Pin C - Blk - GRND
Pin B - Yellow - Lamp/Switch tied to Inst LPS fuse
Pin A - Yellow/Blk to foglamp coil.
Okay, so the middle pin is the illumination, and it is positive?
Thanks.
My guess is its tied off the headlamps switch so the foglights can only be on while the head lights are on. but my guess is yes, its a positive
i just sent you the GM schematic... its not fantastic, but it may help. let me know how you wired yours up! also, the connector for that...i dont have fogs stock...is the wiring for that switch hidden somewhere behind my dash? or am i gonna have to like cut the plastic around the terminals so i can get some regular quick disconnect terminals on it?
