battery post snaped (help) - Audio & Electronics Forum
Monday, April 03, 2006 6:11 AM
my relocated batter to the truck, the lead battery post has snapped off the battery. there is about 2mm that is showing out side the bettery terminal, any suggestions on how to take that out?? the post that snaped off is pretty soft beings that its lead. For those of you who have battery relocators its a taylor made box with the taylor made kit. thanks for the help in advance...
Ryan
**changes are here**
Re: battery post snaped (help)
Monday, April 03, 2006 8:36 AM
Well you have a few choices. 2mm, is gonna be a pain in da ash. Either get a good pair of pliers, or Get a drill, and drill a small hole on the inside of it, and then twist it out that way. The terminal end is lead but its screw shaped, some autopart stores carry replacement parts.
Monday, April 03, 2006 8:41 AM
Ryan (1REDRY) wrote:my relocated batter to the truck, the lead battery post has snapped off the battery. there is about 2mm that is showing out side the bettery terminal, any suggestions on how to take that out?? the post that snaped off is pretty soft beings that its lead. For those of you who have battery relocators its a taylor made box with the taylor made kit. thanks for the help in advance...
Ryan
Top post or side post? And does the post screw out. If so, I know 2mm isn't much, but you could try getting ahold of that with a small pipe wrench, or a pair of channel locks (large pliers with a bend head that adjusts up and down the neck for larger/smaller sizes). I personally would try a pair of channel locks if you have some on hand. Or, go get some if you have the time.
Monday, April 03, 2006 12:32 PM
Cut a little groove in it with a dremel and use a flathead screwdriver and remove it.
Monday, April 03, 2006 2:10 PM
If you have a drill then you can try something like this
1/8 to 1/4 bolt extractor
1/4 to 5/16 bolt extractor
Just don't break one off in the hole when you're using it. You'll never get it out.
Monday, April 03, 2006 2:35 PM
wow.. you all gave me good ideas to go one. if one doesn't work the other will. thanks for all your help.
