I have neons on my car right now (or did, i should say). I was working in the trunk with the system and accidently crushed the distribution block that all the neons plug into and i cant seem to find one anywhere. I really dont want to buy another kit just for that one little piece, so i was wanted to ask if anyone knows where i can get another one, or if there is anything i can do to get them running without it.
Are they he ciagrret lighter adapters? If so you can cut the wires and solder all the positives together and then solder them to the positive power wire. Then do the same with the negative also called ground. Then you will beable to have your neons again .
just about anywhere u can get them man
circuit city, sound advice, best buy.....
der...
No, they are not going to a cig lighter, but i did have a positive and negative going from the switch to the distribution block, then all 4 plugged into the distrib box. So just to make sure i get this right, what your saying is, run all the positives together, and then all the negatives, to the positive and negative coming from the switch?
you shold not be working with electricity
