big three help and pic update - Audio & Electronics Forum
Friday, March 10, 2006 12:31 PM
here is a pic of my altenator now my question is how do i wire the power wire from battery to altenator i cant get my hand in there to put the connection on the alt. and there is no possible way of going from the bottom, is there a secret way of doing this or should i just wait till i get a 200 amp alt. and do it then oh and here are some stereo pics but dont get carried away with comments yet cause nothing is permanent right now just wired up and sitting there so its not pretty yet lol
Re: big three help and pic update
Friday, March 10, 2006 12:38 PM
see that bolt on the rop of the alt, you can put your ground wire there.
As for the power wire for the 2.4, i dont know, to bad you dont have a 2200, cause i have detailed DIY for that engine.
Friday, March 10, 2006 12:42 PM
yeah i actually followed your thread untill i got to the power wire lol
Friday, March 10, 2006 9:27 PM
well you just made my day.
Ill see if i took any pics of my buddies car when i did his 2.4, almost 6 months ago. I cant remember how i did it, i beileve i removed the alt in its entirety to get it to work.
Saturday, March 11, 2006 5:46 PM
just take off as much stuff around the alt as you can..or find someone with small hands, like a carny, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Saturday, March 11, 2006 8:44 PM
lmao thanks wysiwg lol i will probably wait till i get my 200 amp alternator cause i dont think i can get the wire on without taking it off
Sunday, March 12, 2006 2:44 AM
We told you a million times about the caps, yet you still insisted on using them.
Sunday, March 12, 2006 3:12 AM
lol i know but they at least look good lol
Sunday, March 12, 2006 6:21 AM
Lanman31337 wrote:We told you a million times about the caps, yet you still insisted on using them.
chear up, there is a kid down my block with a 500 watt systems and a 20 farad cap.
Sunday, March 12, 2006 6:39 PM
I see the cap war continues...
anyway, I have a 2.2 ecotec, I got to mine by jacking up the car and crawling underneath and looking up... I don't know if that will help you any
Cavillac
Tuesday, March 14, 2006 8:57 PM
Not exactly a question about the Big 3, but....
What type of terminal conectors should I use to connect into the side terminals on my battery? Is there a specific size or type I should look for?
Also, If I have an Optima Yellow Top in my trunk can I just run a fused wire from the battery under the hood to the battery in the trunk or should I just put the yellow top under the hood?
____________________________________________________
2002 2.2L -Base Model- (not for long) Black Cavalier
Tuesday, March 14, 2006 10:35 PM
where is that thread.. i just searched and i cant find it wtf
Wednesday, March 15, 2006 11:50 AM
dirty elf wrote:where is that thread.. i just searched and i cant find it wtf
what thread are you talking about?
Wednesday, March 15, 2006 12:44 PM
El Fuego ( the grounded one ) wrote:cause i have detailed DIY for that engine.
Wednesday, March 15, 2006 1:41 PM
Bill H ('02 Cav) wrote:Not exactly a question about the Big 3, but....
use GM side post adapters from the auto parts store. then just use ring terminals on your wires.
with a battery in the rear, if you don't want to isolate it, then you need to run a 1/0awg cable that is fused on EACH END. within a foot of each battery.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Wednesday, March 15, 2006 2:30 PM
Awesome, thanks.
Wednesday, March 15, 2006 8:32 PM
anyone find that detailed how too for the 2200?
Thursday, March 16, 2006 6:52 AM
Friday, November 03, 2006 7:17 PM
Is this mod only good for when you have a high power audio setup or would it be benificial for any car?
Friday, November 03, 2006 7:58 PM
it would be beneficial for any car because it takes alot of strain off the alternator trying to power the batter. even if you have high power driving lights its a good idea
Saturday, November 04, 2006 3:08 PM
very good idea i have noticed big differences since i installed mine and now we sell them click my sig on the bottom for more info!
Who needs a sig?
www.sinisterimages.com
Friday, November 10, 2006 4:56 PM
Just take your alt off, its VERY easy! Just turn the belt tensioner counter clockwise with a long wrench to take tension off the belt. the belt will then come right off the pully. After that you just have 3 bolts to remove. look at diagram.... Bolt number 1 is easy, just use wratchet and 6" extension. I believe bolts are 13mm...or close...? bolt number 2 is simple too, remove with wratchet again and extension. Add your ground wire to this when you are reinstalling the alt. and bolt 3 is kinda tricky, Its located down between the 2 runners on your intake manifold. I used a wratchet > 6" extension > elbow > 6" entension > 13mm bit....tape them all together so they dont fall apart on you. You dont have to take this bolt all the way out, just loosen it a little bit. Then you can just slide the alt to the left a little and you will see a plug, just disconnect that. Then you will see a wire connected to the alt, just add your new wire to this same location, you dont even have to take the alt all the way out of the car. Reinstall everything reverse of how you took it off and you golden, dont forget to put the plug back on (I forgot this but was able to plug it in even with the alt installed again. and dont forget to add your ground wire to bolt #2. Really this write up might make it sound hard, but its simple. I just did it for my big 3. it was my first time taking an alt out and i did it with no problem. Just hit me up on AIM if you have any questions. z2fst4u24 is my username....
Friday, November 10, 2006 4:58 PM
Oooops, here is the diagram
Tuesday, November 14, 2006 2:09 PM
Hey man whats the dimensions on that box. looks a lil small but how does it sound? looks good
