Ground - Audio & Electronics Forum
Ground
Thursday, March 09, 2006 12:46 PM
I have streetglow pedals that im installing but I have to ground one of the wires. How do I ground a wire?
Re: Ground
Thursday, March 09, 2006 12:52 PM
hook it to something that's bolted to the body. most of the exposed metal pieces under the dash are grounded. for my DRL disable, I used one of the bolts on the OBD-II port, or you can use one of the larger bolts that hold the steering column up.
Desert Tuners
Re: Ground
Thursday, March 09, 2006 2:20 PM
a ground is anything connected to the negative terminal of the cars bettery
a ground will complete the electrical circuit. giving the current somewhere to flow through
notice that the negative terminal on the battery has a short wire connected to a metal hunk on the body of ur engine bay
that makes any other piece of bare metal on your cars body or frame connected to the negative terminal of your battery
so in short just find some bare metal and connect the wire to that with a ring terminal and a bolt or something
now this does not work with the positive side of the battery.. you have to wire that side directly to the positive terminal on the battery or a distrubition block (the positive side must always be fused!)
Re: Ground
Thursday, March 09, 2006 3:34 PM
Thanks guys. I got the pedals hooked up and they look really good. Hopefully I can get some pictures up soon.
