i am having problems wiring in my 2k toyo tails....i got the wiring instructions from the web. it tells you to cut the white wire in the steering column..took apart the steering column and only Found the cruise con trol wire..no white..HOW DID ANY ONE ELSE HOOK THESE UP? Please help
Just pop the top plastic cover off. There will be a group of like 7 wires on the upper left side. Cut the white wire.
Jeremy
Exactly what siegel said, it couldn't be easier. The top plastic cover is the cover that the hazard light switch is on. there are 2 screws under the steering wheel that hold those 2 panels together, unscrew them then pop the top panel off and you're golden.
