where is everybody grounding their amps and caps
http://memimage.cardomain.net/member_images/10/web/2134000-2134999/2134641_3_thumb.jpg
Please tell me you're not using a cap. Seatbelt works fine, there's plenty of places to put a bolt in the back as well.
TO THE FLOORPAN
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
yeah. im using the seatbelt bolt. and it SUCKS. my subs pulse because my amp keeps trying to "reground" itself.or otherwise. i have a "GROUNDLOOP"so please do NOT use the seatbelt bolt
CAV2NV420 wrote:where is everybody grounding their amps and caps
According to you sig, you drive a 2 door midget car. So you can use just about any bolt in your trunk as a ground point.
steps to grounding anything.
tools reqd:
-drill
-bolt or screw
-flat head screw driver or scrapper
-lock washer(optional, but recomended.)
-a wire to ground
1. drill hole slightly smaller than screw.
2. scrap away paint.
3. place wire connector over screw.
4. place lock washer on screw (optional).
5. tighten down.
if this seems like a pointless reply, it is because this is a pointless question. you can ground an amp and cap anywhere, just pick a spot in the trunk. if grounding inside the vehicle, do it where it wont come in contact with water.
have fun.
Injection is nice but id rather be BLOWN!
