I have last years fosgate power 10001bd amp and i havent played with it since i put my car away and dont know where the instructions went, my problem is on the amp it says A speakers +, -, and B speakers +, -, now I forget how to bridge is it A + and B - or just A +- help please lol
http://memimage.cardomain.net/member_images/10/web/2134000-2134999/2134641_3_thumb.jpg
Isn't the power 1001db a mono amp?
anywho you can check
RF Site for the manual - it's in PDF form.
yeah its mono but the speakers outs are confusing me A speakers+-B speakers+-
and i tried the website but it doesnt tell me how to bridge it it just says its bridgable
Got me, I thought they had it online, I used to have one about a year ago.
Would it be that the amp is bridgeable with another amp and not the speakers? My amp only had one speakers outs, I bridge the speakers down to a one ohm load into the amp.
Dunno.
Take your outputs and wire them as follows. From the left speaker output use the +
from right speaker output use the - . You have now bridged your amp.
thanks that what i thought but i had to ask
Shouldn't it show you on the amp?
Every amp that I've ever owned has something painted on there that points it out.. Hmm..
No it doesnt smart ass i wouldnt be asking if it did lol
um its a mono amp. there is no bridging a mono amp. there is strapping of mono amps. the two speaker outputs are there to make hooking woofers up easier. So you dont have to stuff extra wires into one terminal.
so then to answer my question how do i wire up the subs + and - ???????????????ON THE AMP IT READS .....A speakers+ -.....B speakers+ -.. do I just use A speakers+- or do I use A speakers + and B speakers -??????
what are the coils on your woofers? but it should be a+ a- then b+ b-
um its a mono amp.
#5 is the speaker outputs on a Power 1001bd -A MONO AMP!!
You may friend have a two channel amp.
Do this
Problem solved.
the 2 positives and 2 negatives are already connected in the inside of the amp. there should not be an A/B difference. both positives are the same lead. both negatives are the same lead. it does not matter which two you use as long as its at least one + to your sub(s), and one - going back to the amp. or if you want to make it look pretty. run two wires from + on amp to sub(s) and 2 running back to amp.
