My reverse lights are not working. the brake lights and everthing else work fine. could it be a fuse. i have not checked the bubls or the fuses but i will tomorrow. im not sure if by me disabling my DRL's caused this. Any1 know what the problem might b???
more than likely its a fuse
i checked all the fuses and they all work fine. the bulbs seem to be fine 2. what could it be? well when i checked the fuse i couldt find 1 that said reverse lights haha. but i did check all of the ones by my door panel
I have an '02, and when I first bought it, the reverse lights didn't work. turns out there is a switch in the tranny that was bad. it's a dealer part, but it didn't cost that much to replace it. and it was easy to pull it out and put the new one in.
Desert Tuners
I believe this is it:
Description: BACK-UP LIGHT SWITCH
Part #: 90482454
Desert Tuners
thanks ill get on this later.
