Ok im getting 4 new tsw 3002 spl pioneer subs. Ill be running them with an a2200hct audiobahn amp 1600watts at one ohm. The subs will be wired in parallel series to one ohm. My question is how should i build the box like design wise. Its gonna be a wall so i have plenty of space. But what cubic feet should i do and what size the port should be and how do i calculate what frequency the box is built for? Just need some good audio guru advice. Thanks guys.
*2012 mazdaspeed3*
You sure you want to attempt a wall?
RE Audio
Hit up Pioneer. They're probably going to say around 8 cubic feet, tuned around the mid 30's, i'm going to guess around 33-35.
this is just my opion but if you are going to run 4 of those subs which are 1000 wattsrms and 3000 wattsmax each, I would run at least two of those amps possibly a amp on each sub considering the amp only puts out 1600watts @ 1 ohm if your lucky
i think it'll drive em just fine for what i want. And yes i want to attempt a wall i always do what i say im going to do so no matter what it takes the cavi will have a wall in it. Amps can be changed later along with diff subs but thats what i have for now. What can be so challenging about a wall? Maybe fitting it in. I just want to know about the box design. Pioneer says 1.75 cubic feet at teh most but i think thats kinda a little undersized.
*2012 mazdaspeed3*
