I got a birthday this thursday and with the money i'm buyin some components and i was hoping to get the memphis 6.5" m class components.  I'm just concerned about mounting depths.  on the memphis site i says there is a 2.6" mounting depth.  with a 3/4" spacer, is that enough to clear the window?
my depth is 2 1/6 and i've got about 1/4 of an inch space with a 3/4 spacer...
GO PATS!!!
correction to mounting depth of 2 1/16*
GO PATS!!!
so basically, it wont fit without further modifications
never know, i can't be exact with the amount of space i have left...i can only guesstimate because i can see a whole lot behind the door...
GO PATS!!!
well my birthday has come and gone and i ended up getting two new subs instead.  the new subs rock. check  my reg.
Anyways, i still would like to know if anyone knows what the mounting depth from the front of the metal of the actual door panel to the window? i still need to know if i can clear components with at 2.6" mounting depth with a 3/4" spacer.  so total mounting depth would be 1.35" from the front of the door panel to where the window would sit.
Bump.  i really dont have the time this week to measure it myself, if anyone could help me out it would be greatly appreciated.
You should have no problem. Talk to lanman31337 if you have any questions, he knows alot about components
It takes approxamately 3 minutes to take your door panel off.  It might be a tight fit with 2.6 inches.
