Well folks after much searching, and Price comparing, i decided to take a swim.
Now Pep boys, NAPA, Autozone, and every other place i went to find a suitable fuse block only came up with a 5 circuit block for $15-20 usd.
Also it was close to the same as a post here, a long time ago, that had a link to how to make your own.
Well since my fuse block will be out in the open that people can see it, i was looking for a few things before i bought one.
1) At least 5 circuits, the more the merrier.
2) 30 amp max per circuit, 100 amp max per block.
3) Tin, zinc, or gold plated terminals to prevent corrosion.
4) Simple to use, easy access, looks good, IMO.
5) Easy mounting.
Well i finally found one. And here are the Specs and pics.
* 12 circuit with positive and negitive Bus. Accepts ATO/ATC blade type fuses.
* Max amperage per circuit 30 amps, 100 max per block ( more then enough ).
* Tin plated parts.
* Price = $40
Well, what do you think?
yep..looks like a fuseblock to me
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Nice, I had been looking for a fuse block and I saw that one looking on froogle but i wasn't too sure about it. Now that i see that though, I like it.
Where did you get it from???
-Seth
I got it from West marine store.
Yes, from a boating store.
you can also get them from www.bluesea.com
K, thats where i saw them at when searching froogle.
Looks like I have something else to add to the stuff to get list.
-Seth
man i might have to get that fuse block for my setup
Opening Soon Kustom J's
