Heres the Deal im Lookin to Put about $1000 - $1200 nto a system ... heres the Idea
Im lookin for 3 12" subs
and i want each sub to run on its own AMP thus 3 Amps
Heres the Subs Im Thinking ( gonna Grab 3 of Them )
Audiobahn AW1206T 12" 1100W RMS Chrome Flame Q Subwoofer
Brand New Audiobahn AW1206T 12" Subwoofer
12" Dual Voice Coil Subwoofer
1100W RMS / 2200W Peak Power
Dual 4 Ohm Voice Coils
Protective Chrome Finish
2.5" 4-layer Voice Coil
Vented Back Plate For Cooler Operation
Stamped & Balanced Aluminum Cone
Flame Q Design in Basket, Magnet and Cone
Double Stacked 120 oz. Strontium Magnets
2" Foam Surround For Linear Cone Travel
20-500Hz Frequency Response
96.4dB Sensitivity
Mounting Depth 6-3/4"
Cutout Diameter 10-7/8"
Multi-Connect Lug Lock Terminals
Audiobahn Window Sticker
Allen Wrench For Speaker Terminals
Wooden Gift Case
Any Comments on These Subs
What Amps Would u Recommend For These Remeber i want them Each to run Seperate Amp .. Also .. What am i gonna need .. ( battery ? Wire ? what ever else )
Currently i have a 5 Farad Power Cap from power Acoustic
Thanks
I have to give four thumbs down to that audiobahn junk....
as well as running three subs...not a big fan of that one either.
few subs i would suggest...
RE SE
Massive Audio CW
Incriminator Audio Lethal Injection
Soundsplinter
Crystal Mobilsound CMP
American Bass
Crossfire BMF
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
I'm also not too big of a fan of audiobahn subs. I've had a few pairs in my lifetime and have had nothing but trouble.
That wooden gift case should come in handy when or if you decide to sell them.
El Fuego ( the unstable ) wrote:That wooden gift case should come in handy when or if you decide to sell them.
It could also double as a coffin when he has to bury his dead subwoofers in the backyard
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
I'll start diggin the hole now.
You guys are crazy. Audiobling ROCKS!!!!!
RE Audio
What Would u reccomend than .. Sub Wise ????
and 2nd .. whats wrong with 3 Subs ???
kdubbu wrote:What Would u reccomend than .. Sub Wise ????
did you miss the list of subs i put up?
and three subs is lame unless you have dual 6 ohm coils or something...give you an odd load on the amp, as well as not being much louder then 2 subs.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
wysiwyg wrote:kdubbu wrote:What Would u reccomend than .. Sub Wise ????
yah i noticed the List . .any Good Sites to Pick up any of those at a good Price ??
kdubbu wrote:wysiwyg wrote:kdubbu wrote:What Would u reccomend than .. Sub Wise ????
search the net
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
I would go with anything Diamond Audio. I have 2 12's in my 2k Z24 on a HiFonics 1500w mono block class d amp. I can't turn the gain up past quarter of the way up or my wipers won't stay on the widshield.
The midwest is here....... are YOU ready.
Personally ill stick with my Infinities. Not SPL based, but i like hearing every beat, every note without distortion.
what does gain, fade and stuff on an amp mean???
"Sunfire got stolen, all i have is the J to remember it by"
theres nothing wrong with doing 3 subs, you said 3 amps to go along with them... no weird impedences... 2 ohms each. 3 subs is a lot more surface area than 2 and you dont have to push them so hard to get the same SPL numbers. I would have to suggest against the 3 amp dealio though... you want to spend $1200.... each amp(if decent) is gonna run you about $400 at least. I suggest one BIG amp that will be 1 ohm stable and get three- dualVC 2ohm subs, running at 1.33 ohms. If you want it to sound a little better, spend the extra $$ on the seperate amps and it'll sound cleaner and you get the bling factor. as for audiobahn... looks cool.. not nicest sounding, great for show car though. good luck
Gain is used to match voltages from the source unit.
Fade is volume front to back.
Stuff on an amp means you better wipe it up soon!
why not go with 3 12" se's and a orion 2500D i think that will give you a .66 ohm load (to tired to think)
i had 3 jl 12 w3 d4's and they hit hard
I have 2 JL W7's and they hit like crazy
