trunk battery install - Audio & Electronics Forum
Thursday, February 09, 2006 10:58 PM
I was wondering on how to wire up a battery in the trunk so it is able to stay charged? Where does the wire connect to? any help would be appreciated
Re: trunk battery install
Friday, February 10, 2006 4:29 AM
same place it connects to when its under the hood......just needs a longer cable to reach the trunk...and it has to be a bigger gauge of wire...and if you ever go to the track you need an external on/off switch
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Friday, February 10, 2006 7:46 AM
Neg goes to chassis. Pos run a 0 guage to the front stock location.
Friday, February 10, 2006 8:16 AM
would you benefit any running the constant off the alternator? so it's gettin a direct charge instead off pulling it from the battery and the alt having to run 2. it's kinda like a capacitor if it's ran off the cars battery. I'm just asking this to get some answers myself. I've always though it would be better but dunno cause I've never done it.
Friday, February 10, 2006 8:25 AM
The01Cav wrote:would you benefit any running the constant off the alternator? so it's gettin a direct charge instead off pulling it from the battery and the alt having to run 2. it's kinda like a capacitor if it's ran off the cars battery. I'm just asking this to get some answers myself. I've always though it would be better but dunno cause I've never done it.
electrically speaking, it's the same either way. the alt still has to charge both batteries. and the wires will still be connected the same just at a different end.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Friday, February 10, 2006 9:16 AM
does it have to be 0awg or can i use 2awg?
Friday, February 10, 2006 9:22 AM
CAV2NV420 wrote:does it have to be 0awg or can i use 2awg?
either or will be fine. the bigger the better though.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Friday, February 10, 2006 2:33 PM
Ditto. Make sure it is fused less than 18" away.
If you are thinking about competition; it has to be securely mounted, sealed and vented outside the car.
^CLICK ME TO SEE HOW I BUILT EVERYTHING^ How To in Interior Forum
Friday, February 10, 2006 2:52 PM
what is to be vented and how?
Friday, February 10, 2006 3:08 PM
If your not using a gel battery like an optima battery (the big yellow thing in my sig), your battery needs to be vented.
In another words, you buy a $15-20 battery box, put your battery in it, secure the box with battery to the car, by either a bolt, or velcro, then you have to have an air vent. You put a hose through a knockout found on most battery boxs, or drill a hole in the BOX, and only the box if needed. Route the other side of the hose either to one of the rear trunk vents or under the car.
If you dont, pressure could build up in the battery and explode.
Save our Environment, Plant a bush back in texas.
Friday, February 10, 2006 3:16 PM
Mennitti wrote:Ditto. Make sure it is fused less than 18" away.
yes..also fused within 18" of BOTH BATTERIES..meaning you need two fuses on the wire connecting the batts together
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Friday, February 10, 2006 3:48 PM
so if i have a gel battery i dont need to vent it? and i also add a fuse at the front part of the car and also at the back?
Friday, February 10, 2006 3:53 PM
CAV2NV420 wrote:so if i have a gel battery i dont need to vent it? and i also add a fuse at the front part of the car and also at the back?
correct.
Friday, February 10, 2006 6:24 PM
I thought you did your own custom labor, you should know this answer already.
Sunday, February 12, 2006 3:50 PM
like i said before im not a professional but i do enjoy making everything for myself, as far as the battery question I just havent bothered hooking up a second battery before so i thought i would ask for help instead of blowing something up
Sunday, February 12, 2006 8:44 PM
so you can wire two batteries together w/o an isolator?
what if you want accessories on one batt and the car on the other?
sorry not trying to jack your thread.
Monday, February 13, 2006 4:19 AM
Machzel08 wrote:so you can wire two batteries together w/o an isolator?
then you use an isolater
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Monday, February 13, 2006 6:04 AM
thanks, thats what i thought
where can i get an isolator, cheap preferably
Monday, February 13, 2006 6:40 AM
Check your local auto parts store.
Monday, February 13, 2006 8:24 AM
Machzel08 wrote:thanks, thats what i thought
Go to a boating shop. Marine battery isolators are high quality and pretty sweet looking.
Monday, February 13, 2006 11:21 AM
You can also use a circuit breaker, plus a bigger amp alternator is helpful
Monday, February 13, 2006 1:19 PM
firerescue88 wrote:You can also use a circuit breaker, plus a bigger amp alternator is helpful
a circuit breaker instead of an isolator? please explain
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, February 14, 2006 4:43 AM
I think he meant instead of a fuse.
A second battery, plus amps with a decent amount of wattage, will kill your alternator. Last year I had to replace both Optimas, we thought 1 had a bad cell and killed both. This year same problem, found it to be a leak past the rectifier bridge of the stock alternator draining the batteries. The stock alternator can't keep up with demand and dies. So I got an Ohio Generator alternator.
car sound and performance forum
A friend of mine a few years back had a system in his cavalier and it constantly had a battery issue. He brought it to me to figure out what was going on.
1. The first problem was that the cavalier alternator could not keep up with the electrical draw of all the components in the car.
2. I was surprised my self how much the car it self drew with the lights on and AC on, it ended up close to 45amp of draw without the stereo system on.
3. Then I tested with the amplifiers on at a loud listening level, his car was having peek current draws of 182amp of draw. Average draw of 130amps.
4. So simple math 65amp alternator minus 182amps draw = - 117 amp. So his system was running in the negative. Which meant for the car to keep going it was drawing everything from the battery to the point where it damaged the battery.
5. I replaced the battery and before replacing the alternator found that there was a draw leaking past the rectifier bridge in the alternator. It was small but enough that in a few days time it could kill a battery.
6. Last but not least I got him an Ohio generator that put out 150amps I told him that this was boarder line of what he needed for his system since he was averaging 130amps of draw and peaks of 180.
7. All this seemed to fix his set up he still has his car with all the equipment in it and no more dead batteries.
Tuesday, February 14, 2006 5:16 AM
Do they make a high output alt for the ecotec motor
*2012 mazdaspeed3*
Tuesday, February 14, 2006 3:15 PM
if you do want to use a circuit breaker, i have a 135a stinger breaker for sale. cheap
