I have an alpine type r 12 DVC sub hooked up to a V12 605 amp. The Sub is in a sealed box and is bridged down to 2 ohms. I cant figure out whats wrong with it. it just doesnt sound good. Anyone else have the same problems?
What are the box dimensions?
Do you have a link to the box?
How do you have the subs wired?
Are you running a stock deck?
Need more info mang.
do you have the sub wired properly? where are the positives and negative wires going?
Alpine MRD-605
High performance subwoofers place high demands on amplifiers and require enormous power for maximum performance. That¡¯s why we developed the ultra-efficient, ultra high-power V12 Class-D digital mono amplifiers. They¡¯re designed to
600W x 1 RMS [2§Ù @ 14.4V 1% THD]
400W x 1 RMS [4§Ù @ 14.4V 1% THD]
400W x 1 RMS [2§Ù @ 12V 1% THD]
250W x 1 RMS [4§Ù @ 12V 1% THD]
S/N Ratio 90dBA (IHF A Weighted Reference at Rated Power into 4§Ù)
Thermal Management
Now $799
sorry guys
Its a sealed box
I have my subs bridged down to 2 ohms. (+)+ (-)-
Im running an aiwa deck right now
What are the dimensions of the box?
Go measure it when you have time.
Also...where did you get the box? Alot of pre-fab boxes are build with 5/8" MDF or particle board instead 3/4"...which causes resonance and can hurt sound.
Its a pre fabed box from best buy
your problem is the prefab box, aiwa deck, and bad tuning. Fix all 3 and you will have good bass, there is no QUICK fix to this problem. (make sure the box is proper demensions.)
My Cav
I give up...
definetly start with building a box around 2.5cu/ft ported
max I would go with would be 2.0 cubic FT net.
Box plans check this out it will tell you what you need.
