What amp should I go with?
They're the same price I'm runnin it @ 2ohm. I think that they're pretty much the same amp so I'm not sure which one I want to use. My boy got the viper to run to older r's in 1 ohm and it's pushin pretty good. But I also have heard a directed audio amp push a sub pretty good to.
Viper D1200.1
Dynamic Power Rating: 1500 watts
S/N: > 80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 450 x 1
Rated Power @ 2 ohm: 800 x 1
Rated Power @ 1 ohm: 1200 x 1
Crossover: var. 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L
Directed audio 1500D
High speed MOSFET switching power supply
High current complementary MOSFET outputs stable into 1 ohm loads
Thermal, DC offset, over/under voltage, reverse polarity and short circuit protection with status LED
Master/slave RCA jack functions support two amps bridged to one load, or multiple amps driving separate loads with synced gain
Top-mounted controls easily accessed for system tuning
Continuously variable 18 dB/octave low-pass crossover
Switchable 30 Hz, 24 dB/octave subsonic filter
Switchable 8 dB bass EQ function
Switchable phase invert function
Power ratings
Rated Power @ 4 ohm: 425W x 1 RMS
Rated Power @ 2 ohm: 800W x 1 RMS
Rated Power @ 1 ohm: 1100W x 1 RMS
Dynamic Power Rating 1500 Watts
General
Class d (digital amplifier)
S/N > 80 dB
Frequency Range 20-250Hz
Damping Factor: 50 (typical)
Input Sensitivity: 150mV to 8V
Crossover: variable 18dB low-pass
8db Bass EQ
RCA Output
Protection circuits: Thermal, Short circuit and DC offset
they are the same amp the viper is the same as the dei 1100. about 2 years ago dei changed there amps and just out them in new case's so just pick whatever you think looks the best.
i had a viper 2500D (same as dei 2400) and two 1500D's all vary good amps for the $
Yup get whatever's cheaper. i recently sold a 1500d that I loved. Put out it's rated power and them some with ease.
I'm gettin em from ikesound.com they're both $125
DEI discontinued the viper line.
just throwing that out there
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
