Bypass - Audio & Electronics Forum
Bypass
Monday, January 16, 2006 7:04 PM
I have a 96 cavalier ls sedan with a prestige alram with the option for remote star. however i do not know what bypass i need to use
when it comes to boobs i need a girl with bad grades cause im tired of all the ones walking around with straight a's
Re: Bypass
Monday, January 16, 2006 7:43 PM
DEI or equivalent 555L.
Should be around $20.
Re: Bypass
Monday, January 16, 2006 8:28 PM
how do i install it
Re: Bypass
Monday, January 16, 2006 9:27 PM
red : constant 12V
pink: ignition
purpal: ( needs to see ground during crank) use accessory
black/white: bulb check wire ( this wire is found in the power plug at the ignition switch up at the colum, It is a black wire next to the 2 reds
black/yellow: car side of the yellow resistanse passlock wire
black:: ground of the passlock wires
yellow: keyside of the yellow passlock wire
after everything is hooked up, run the car for 6 secinds.. the bypass is learned.. remote start
Re: Bypass
Tuesday, January 17, 2006 3:50 AM
purple and black/white shouldn't be hooked up to anything, theres a blue wire that needs to be hooked to a negative status output from the remote start to activate it.
-Chris
