ok so i bought this alarm from a group purchase here a very long time ago. but i didnt have my car for a while so i never bothered to put it on. Now i need to install it.
Its a car security and alarm system. it turns the car on and stuff. i need to know the ignition harness. and what ground to use.
these are the instalation thingies.
1. power connection
2. ignition connection
3. accessories connection
4. start wire and started disable
5. ground connection
6. siren connection
7 trunk release
8 turn signal light
9 door trigger
10 hood trigger
11 break pedal
12 alternator input
13 car call sensor
14 shock sensor
15 antenna
also do j -bodies have a (-) output system or a +12 v output system. whats the difference
also doe we have a (+) or a (-) pulse signal
i also bought a new face indiglo. (the one with the mph and gas and stuff) but i cannot get it to turn on at night only when i switch my headlights on. i have it connected to some fuse on the side so that as soon as i turn on my car the damn thing comes on.
also how do i get my aftermarket radio to turn on using the acc function without having it on ON.
PLEASE I NEED ALL THE HELP I CAN GET. either by email or in person. im in boston, ma
soon to be in jacksonville florida. i want to get all this done before i leave tho. thanks.
"Sunfire got stolen, all i have is the J to remember it by"
dunno bout the alarm
indiglo gauges, wire the power for it to the headlight switch, that way when u turn on the headlights it will get power and turn on
headunit, find a fuse in the fuse box that is hot in acc/on and wire te HU's power to that
whats the headlight switch.
which wire in the head unit is it???
how can i tell what wire is hot in acc/on?
run ur power wire from ur head unit off the stock power wire from the factory hu.
1998 Sunfire, 2.2L auto
please search
the gauge thing was discussed about a month ago and all the info you need is there
Ryan Shissler wrote:run ur power wire from ur head unit off the stock power wire from the factory hu.
i did this but it still does not turn on when i put in on acc...
luqiuid fire what should i search for so that it comes up. i cant put in gauge thing
odd... My cd player turns on when the key is turned in any position
alright guys....thanks for those responses.....
i need to install my alarm and ima do it today and..tomorrow.(seing as daylight dont run past 4pm here and that its sorta warm)
what i need to know in as much detail you guys can is to what color wire do i connect these and where that wire is...i have a 2002 pontiac sunfire coupe.
1. power connection
6. siren connection
7 trunk release
8 turn signal left and right
9 door trigger left and right
10 hood trigger
11 break pedal
12 alternator input
this is the wiring guide
c1 power and remote start wire
RED P/A to fused constant +12v main power
GREEN P/B IG1 OUTPUT (remote start) +12v @30 amps
WHITE P/C ACC wire for heavy load +12v @30Amps
YELLOW P/D Start motor output +12v@30 amps
BLACK P/E ground to chassis
PURPLE P/F armed output (for start disable) ground at -500mA
c2 5 pin connector
RED 5/A not connected
YELLOW 5/B Siren output +12v@1.5 amps
WHITE 5/C output for trunk release +12 volts @15amps
PURPLE 5/D output for turn signal light +12 volts @15amps
PURPLE 5/E output for turn signal light +12volts @15amps
c3 6 pin connector (DONT WORRY ABOUT THIS ONE)
ORANGE 6/A output for door lock 15a
WHITE 6/B output for door lock 15a
YELLOW 6/C output for door lock 15a
ORANGE/BLACK 6/D output for door unlock15a
WHITE/BLACK 6/E output for door unlock 15a
YELLOW/BLACK 6/F output for door unlock 15a
c4 5pin connector
PURPLE 5/a (+) Posituve for door trigger input
BLUE 5/B (-)negative for door trigger input
GREEN 5/C (-)negative hood trigger input
ORANGE 5/D (+) positive break pedal input
YELLOW 5/E (+) positive alternator (generator) imput
