wiring up neons - Audio & Electronics Forum
wiring up neons
Monday, January 02, 2006 2:27 AM
i just put my neons in the car and i have a few wiring questions... thanks
1. the switch can be on the ground or the positive side correct?
2. i can go from two of the same gauge wire to one of the same gauge wire on both positive and negative with out needed additional fuses correct?
3. hard wiring to the battery, good idea or not? any other relativly easy solutions?
4. what size fuse do i need for like 24 gauge wire? its the stuff that was on the end of the neons... is 15 amps to big?
ill prolly have a few more soon but those should do it for now
Re: wiring up neons
Monday, January 02, 2006 9:31 AM
no fuse is ever too big lol just hard wire it, and when you make your connections make sure you lick your fingers before you do it!!!
Re: wiring up neons
Monday, January 02, 2006 3:04 PM
yea fuses can be too big...
if its too big it lets enough current through to burn up the wire anyways.. hence the point of a fuse
Re: wiring up neons
Monday, January 02, 2006 3:29 PM
What neon kit do you have?
-Chris
Re: wiring up neons
Monday, January 02, 2006 3:37 PM
i just put 2 12" bars under the dash not an underbody kit
Re: wiring up neons
Monday, January 02, 2006 3:55 PM
1. the switch can be on the ground or the positive side correct? Yes
Yes, but it is recommended to have a larger gauge wire -- 1 to 2 steps up from whatever you are joining.
Good idea, keep the fuse as close to the battery as possible. Also, the battery output post on the alternator should be 12v hot at all times
4. what size fuse do i need for like 24 gauge wire? its the stuff that was on the end of the neons... is 15 amps to big? Check with the manufacturer for recommended fuse size.
Re: wiring up neons
Monday, January 02, 2006 9:46 PM
well i just finished putting them in,
i switched the ground side
i didnt go a step up in ga wire, but i think its fine
hard wired to the battery, the fuse is about 5 inches away
used a 7 amp fuse
only problem i have is that the drivers side doesnt light up.. i think the bulb is broken tho
i had it all wired up and i checked the current with a mulitmeter and its getting current on both sides of the tube, it just doesnt light.. so i assume its dead
only thing i can think of, if the bulb isint dead then im at a stand still.. i checked all the connections and everything, its all up to par, even soldered most of them
ill get a new neon bar tomorrow and let you know how things go
any suggestions let me know
gimme a few secs ill post up how i wired them
Re: wiring up neons
Monday, January 02, 2006 9:55 PM
heres how i did it, its pretty simpe so im really hoping its just the bulb thats bad
Re: wiring up neons
Monday, January 02, 2006 9:56 PM
man im really sorry for the triple post but i just realized i just picked random wires coming off the neons to be + and random ones to be -
could that be it lol...
let me go try that
Re: wiring up neons
Monday, January 02, 2006 11:54 PM
nice drawing!!
Re: wiring up neons
Tuesday, January 03, 2006 8:39 AM
dirty elf wrote:man im really sorry for the triple post but i just realized i just picked random wires coming off the neons to be + and random ones to be -
let me go try that
Yes, that could be your problem
Re: wiring up neons
Tuesday, January 03, 2006 8:19 PM
yea i guess its not just like a normal light blub, there are determined + and - sides
thanks, its all working great now
