Hi I have an 04 ls sport and a viper alarm/electric starter......it works the trunk, door locks and alarm and starter....yesterday it rained here and i happened to have gone thru a good size amount of water......and everything works but the alarm is very very low now...you can barely hear it....it used two chirp twice loud when the door was locked and the lights would flash.....and once when the door was unlocked and the lights would flash well like i said everything is working but the CHIRPING NOISE IS VERY VERY LOW ALMOST NON EXISTANT......IT'S BEEN DRYING OVER NITE NOW AND STILL VERY VERY LOW......DO I WAIT TIL THE WEEKEND ALTHOUGH NOW ITS GETTING COLDER IN THE 30'S HERE OR DO I TAKE IT BACK TO WHERE I GOT IT INSTALLED AND LET THEM DEAL WITH IT.....ANY HELP IS GREATLY APPRECIATED....
THANKS IN ADVANCE.
http://members.cardomain.com/bozeybeau
They probably put the alarm horn in facing up. And it's probably full of water now.
I installed mine below the drivers headlight on the frame rail facing down. Relatively protected spot, where no water is going to damage it.
No. You need to un bolt the siren and dump the water out. Take it inside the house and let it dry out. Then reinstall it but this time point it down so that won't happen again.
ok i'm new to this so when i open the hood where should this be and what am i looking for .....i know it sounds stupid but i've never done anything like this....thank you
It could be located just about anywhere. Alot of install places put it on the firewall of the car, others hide it around the front bumper somewhere. Just look for a small, square black siren that has a red and red/black wire going to it. Hopfully it didn't short out a circuit. If that's the case, you need a new siren. Just dry it out and see what happens. Good luck.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
ok so i opened the hood and saw this litle siren and i found it ...its pointed down but its right up on top of the engine wall like below the windshield area.....i felt inside it feels dry....so if i need a new siren what do you think that will cost?????
THANKS IN ADVANCE...
Sounds like a bad ground to me. The ground could have corroded or rusted. If it is a Viper it should have a lifetime warranty through the shop that installed it. You should take it back there and have them look it over.
We had the same problem last winter. A car's siren was very dim, and he just moved to the area. Since we are the Viper dealer we fixed it. Turned out the shop hadn't soldered the ring terminal on the ground wire so it corroded, and the shop didn't chose a good spot for grounding it.
^CLICK ME TO SEE HOW I BUILT EVERYTHING^ How To in Interior Forum
