im killing my batteries!!! - Audio & Electronics Forum
Wednesday, November 30, 2005 11:59 AM
Can someone offer me a good circuit to tap into so i don't keep forgetting to turn my amp off? im runnin my amp off a switch (i still got my stock deck) and i keep walking out to my car to find out it's DEAD! feul pump maybe? i donno?
Re: im killing my batteries!!!
Wednesday, November 30, 2005 12:03 PM
if its anything like the 2002's there should be a wire in the steering wheel you can tap into that detects when the key is turned and you can use that for you amp we used it for my friends cd player.
look around i "think:" this is a good idea
Wednesday, November 30, 2005 12:56 PM
the ignition circuit? that would be nice, which wire is hot?
Wednesday, November 30, 2005 1:06 PM
Sketch Hack wrote:the ignition circuit? that would be nice, which wire is hot?
There are 3 ways to find out.
1) do a search, its talked about every day.
2) get a volt meter, and check
3) pull back some of the insulation, lick your fingures and touch a ground and the wire at the same time. ( I dont recommend this way )
Wednesday, November 30, 2005 1:14 PM
1) yes your right if the search was worth a damn.
2) no money for dvom, only got test light and i dont want to start pokin wires.
3) haha funny, fingures*
4) El feugo means (the fire)
Wednesday, November 30, 2005 2:00 PM
Sketch Hack wrote:1) yes your right if the search was worth a damn.
#4 is correct, But my ond name was LMR the unstable. so i kept it.
Wednesday, November 30, 2005 2:07 PM
Go to an auto parts store and buy a fuse tap and then plug it into your wiper fuse.
Wednesday, November 30, 2005 2:22 PM
This is what it will look like.
The reason for one like above and not one like below is because it adds a fuse for what you are hooking up to it. You don't want to be driving in the rain and blow your wiper fuse and be stuck with no wipers
Wednesday, November 30, 2005 3:16 PM
hmm..helpful, the wiper circuit is hot during "key on, engine off" or "key on, engine running"?
Wednesday, November 30, 2005 5:09 PM
12V| red |+ |ignition harness
STARTER| yellow |+ |ignition harness
IGNITION| pink |+ |ignition harness
ACCESSORY| orange |+ |ignition harness
SECOND ACCESSORY| brown |+ |ignition harness
does that help?
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Wednesday, November 30, 2005 6:50 PM
Sketch Hack wrote:hmm..helpful, the wiper circuit is hot during "key on, engine off" or "key on, engine running"?
Key on, engine off.
Thursday, December 01, 2005 6:23 PM
aint that somethin, thanx alot you guys.
