Well yeah, prob a dumb question, but I have everything ready to go. I have a new bronze battery tap/nut for my power wire for my system. I unscrew the positive terminal and the nut won't come out from the terminal. It comes out of the battery fine but how do I get it out of the positive terminal so I can replace it with the new one? It just won't come out. Did I miss something?
Im a little confused. I assume you have side terminals. And have one of these:
Or something like it, right?
If the nut on it is not coming off, try pliers or a wretchet and socket.
But if your talking about the actual battery nut, then its not supoosed to come out from the battery.
I think what he means is that it won't come out of the red plastic cover that surrounds it. I had the same problem when I replaced mine. You just have to get a screw driver inbetween the nut and the red plastic cover, and pry away. It will eventually come out after a little work.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Yep, thats it. Just pry eh? I'll let ya know how it goes, haha. Thanks.
had the same problem, now since i have that extension it comes awfully close to my intake. if they touch my BCM shorts out and my odometer will say error!
Well I feel like a retard. That literally took me 2 minutes to get out. Just didn't see how big it was inside the red plastic. Just get a flat tip, stretch the plastic, and pry. Hope this may help someone.
Sketch Hack wrote:had the same problem, now since i have that extension it comes awfully close to my intake. if they touch my BCM shorts out and my odometer will say error!
Keep doing that!
No seriously, insulate that @!#$ dummy
