Too many hook ups to battery? - Audio & Electronics Forum
Sunday, November 27, 2005 3:29 PM
I hooked up my radio direclty to the battery and it was working great, and then i decided to hook up fog lights on the directly to the battery as well, dor some reason when i turn on the lights, it blows the fuses all the time-and now my radio doesnt work either. Is that because i hooked up two things right of the battery????The radio's fuse is probably blown as well? What do you think?
Re: Too many hook ups to battery?
Sunday, November 27, 2005 3:31 PM
Sounds like yu got a short my friend in your wirering..retrace it and make sure your not grounded out anywhere....and no..you can have aton of stuff cmming off your batt...no biggie..phil
Sunday, November 27, 2005 3:43 PM
now what do you think happened to the radio though?
Sunday, November 27, 2005 7:33 PM
That i have no clue man...umm is it stck radio?or did you wire it in??phil
Sunday, November 27, 2005 7:50 PM
Its definitly a wiring problem. And why do you have your radio connected straight to the battery? Thats the incorrect way to do it.
Sunday, November 27, 2005 7:51 PM
Acually not so my man..if its an alpine it says to do that..hahaa..but who knows ..ive seen wierder things..phil
Sunday, November 27, 2005 8:21 PM
my radio is a Kenwood KVT 715 dvd player, hey if i dont hook it to battery what is a better place to hook up the yellow (battery wire), I mean I had working until I tried to hook up those bloody fog lights, I just dont see what is going on.
Sunday, November 27, 2005 9:34 PM
Philly D wrote:Acually not so my man..if its an alpine it says to do that..hahaa..but who knows ..ive seen wierder things..phil
I have an alpine, and says to hook to a switched 12 volt source.
Wiper fuse tap is a better choice. Not the best, but it is better.
Monday, November 28, 2005 1:59 AM
alpine v-drive h/u need to be connected to the batter it see thier full out put if your using the internal amp on the h/u
Monday, November 28, 2005 6:47 AM
You're talking about two different wires here. The wire you're talking about is the red ignition power wire, but everyone else is talking about the yellow battery/memory wire, which should get constant 12 volts. There is nothing wrong with hooking the yellow wire up to the battery, like a few other people said, you will probably actually get better performance out of your deck.
-Chris
Tuesday, November 29, 2005 6:18 AM
the yellow wire is by all means a direct connection to the battery. Your not going to get anymore apmerage by directly connecting it than you are connecting it via the yellow wire because the guage of the wire in the harness isn't any bugger than the stock 12v constant.
However, you should ground the headunit to the car chasis, not the black wire.
If your using an alpine headunite use a nice set of components and some amps, don't bother with the internal amp.
-Chris
Tuesday, November 29, 2005 6:55 AM
The yellow wires (it has two) on my Clarion deck are a noticably larger gauge than the factory wiring.
-Chris
Tuesday, November 29, 2005 3:28 PM
^ i wonder why... lol
