Has anyone on here put a starter kill switch on their car? I am wanting to put a hidden switch wired to my starter so when i kill it, you cant hot wire the car, plus its an insurance discount. If im not mistaken, i would just wire to the power going to the starter correct?
Thanks in advance for any help
04 Cav 2.2 Ecotec
Yes but I would imagine starter sucks up a lot of amps so unless you like having big ugly industrial looking switches in your cabin (and heawy guage wire going to it) I would tell you to use a relay and a normal switch.
Alternetavly why not just put a fuel pump cut of switch? it should be easier, just add a switch in series with the fuel pump fuse.
Yeah, that is a better idea, thanks man
04 Cav 2.2 Ecotec
well, you can use a smaller switch, but switch a relay, that in turn will swicth the starter solenoid
wait for it... wait for it... NOW GO!! ---> '02 LS Sport <---
Yahoo IM : buzz122 AIM : buzz122cav
ok, thanks for the ideas, it will be my project before the year ends
04 Cav 2.2 Ecotec
yea a kid in my auto body class got a Honda Civic Hatchback from some people in New York and i took a look at it and right inside the door under the dash is this massive steel wire loom and this big freakin black box, looks like a light switch box for in a wall. he said its the kill switch for the starter but they didnt have the key to it anymore. Ugliest thing i have ever seen.
1998 Sunfire, 2.2L auto
Your car already has an immobilizer system built-in, and while it's not perfect, it makes it hard enough to steal your car that a kill switch becomes redundant.
I have a friend who wired up a smoke detector to a kill switch so his brother couldn't smoke and drive
Corsica Dude wrote:I have a friend who wired up a smoke detector to a kill switch so his brother couldn't smoke and drive
thats funny.............
buzz122 wrote:Corsica Dude wrote:I have a friend who wired up a smoke detector to a kill switch so his brother couldn't smoke and drive
wow and one more thing that IM sure was said
PASSLOCK if we didnt have It i would of stayed away from a start button.
boobs now with Riboflabin"
If passlock is so good, than why do so many cars still get stolen with it?
04 Cav 2.2 Ecotec
if a thief wants a car bad enough they WILL get it, you can bypass the passlock with a simple resistor.
what makes you think put putting a switch in the car will be any safer... all they have to do is flip a switch....
easy way to do a little something, pull the fuse for the fuel pump or starter of something when you park, granted a thief could just pull out the fuse for the horn or somethign and put it in its place but I duoght they will sit there ard try to figure out whats wrong with it... its simple, easy, and free to just pull a fuse
good point
Yeah, they can flip a switch if i put one in there, but they also have to search for it, im not going to put it out in the open, it will be hidden, and only me and my wife will know where it is at.
04 Cav 2.2 Ecotec
the your wifes boyfriend too, dont forget
i got a sig warning
boosted cavfire
If you have the starter relay recall done, then just put a switch on the starter relay (under the hood, usually mounted on the front frame rail). It's now a low-current circuit after the recall is done.
I havent received anything about a starter relay recall
04 Cav 2.2 Ecotec
