whats the differernce between dual and single voice coil?which one is better?sorry new to this audio thing,and by the way is this woofer good ?
bazooka p.miller
Single Voice Coil, Dual Voice Coil.
Single voice coil, for example, 4 ohms the amp sees 4ohm when connected.
Dual voice coil, 4 ohms per coil, can be bridged so the amp sees 2 ohms and in most cases, delivers more power to the speaker.
2 4ohm DVC speakers can be bridged to 1 ohm... overloading some amps but providing lotsa power to amps that are capable of handling it.
the only difference is your wiring options. a dual voice coil subwoofer will give you more options
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
how do you bridged a DVC? right now i have a audiobahn AWC10T and has a DVC
yeah, bridged was poor terminology... I was typing in a hurry.
The 2 coils can be wired in parallel or series so that the amp sees a lower or higher resistance.
hey many thanxs man now i know cos im just powering 1 coil and i bridged my amps to mono 2 ohm stable
Only powering one voice coil is a bad idea.
-Chris
but how can you tell their polarities?+- mine doesn't say which ones + or -
sometimes, 1 prong will be smaller than the other. smaller prong is usually negative. Most of the time, it's stamped in the piece the prongs are attached, or marked on the basket of the woofer above the prongs.
isn't dvc a little bit stronger than svc because it is a layered voice coil?
Go Premium, it builds character!
howe0822 wrote:isn't dvc a little bit stronger than svc because it is a layered voice coil?
ah...no
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Maybe a terminal will be black, then the other red? Red would be + Positive. Now. you must run both voice coils or you will fry.. something.
usually DVC subs just take more power for the fact that they are all around (usually) nicer subs.
cavy:bagged easystreet front, bags to be in in back soon, tubd, 18s.
celica gt-s:6speed, AEM Cold air, hi flow cat, muffler deletion, NGK plugs, Carbon fiber headliner, B&M shift kit, sportline 2.2" drop, factory rear disk brakes
1/4: 14.5sec. top speed: 145mph
