for some reason it stopped working. the only thing i can do with my control is unlock the drivers door and set the alamrm. it wont lock it and it wont lock.open the other doors either. very annoying. any ideas?
Check the connections and the fuses. I had a similar situation with mine.
^ check your "pwr acc' fuse, and see if its blown. the other would be is check the battery on your remote. just use a flat-head screwdriver and lift up on the larger than the rest crease. third would be, and the harder of the bunch, is checking the lock actuators for loose or worn wires. best bet for that is look up the wires if you have a haynes manual or chilton's or use the search function on here to find a schematics of it if someone posted it. hope that helps.
*Devil Z*
nothing seems to work. i changed the battery in my remote not too long ago, the fuses are all fine. the drivers side works to unlock and thats it. it arms the alarm too, but no locking from anything of them. just drivers unlock. i here clicking under the steering wheel when i hit buttons, like its trying to do something and it cant. i dont know where its coming from though, sounds like the BCM or something.
i accidentally left my windows down and it rained the other day, if thats any help. i closed my windows pretty fast though. i guess it got a good 5 minutes open. the locks were fine before that but it happened a good 2 weeks before they gave out.
Is this for your 01 Sunfire?
welll i guees the relay is clicking under your dash, so you might want to take fst_99Z24 advice, open each door and see if you can test each of the actuators.... there in might lie your issue.....
wait for it... wait for it... NOW GO!! ---> '02 LS Sport <---
Yahoo IM : buzz122 AIM : buzz122cav
