I'm looking for the locations of three wires so I can finish my alarm install.
Horn - Black wire in steering column. I have no idea where it's at.
Door jam switch - light green/black and light blue. I have no idea where it's at. Is it in the big cluster of wires by the driver's side kickpanel? I've been hunting for these for a while now, and no luck. Anyone know where these wire are near to give me a reference?
http://www.cardomain.com/id/lanman31337
Sponsored by:
JLCaudio.net
Ok the horn is in the cluster of wires that runs down your steering column, you will need to take the bottom cover off the steering column.
as for the other one i have an 05 so mine is different.
The green/black is located in the lower drivers kick panel. It catches the drivers door only. The light blue is located in the lower passenger kick panel, and catches the passenger door(s). Tap both wires and diode isolate each.
I would just leave the horn out- I think its annoying, especially if you are using a siren as well.
YAY I found them!!!! On the driver's side, off the main cluser, there's a black taped set of wires, which houses the driver's side wires for the door jamb switch. The passenger side are bundled with the radio wires to the door and they're in hot pink electrical tape. Thank you again guys.
Sponsored by:
JLCaudio.net
