Looks right to me.
Im guessing that the fuse is a constant supply?
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
Yeppers. Looks good to me.
i thought leds were supposed to be wired parallel not in series?
leds should be wired in parallel, but for small numbers can be run in series.
Causa latet vis est notissima
DIY Clear 03+ Headlights
good catch. I didn't notice that the first time through...
but according to the op, sounds like there may be one already as the LED's were already coming on.
<shrugs>
I figured since there wasn't any poping or sizzeling, that they are 12V LED's lol
Alright I figure I should tell you that it is a fire hazard to have a wire going into the fuse box if you just have the wire wrapped around and tucked in with the fuse. Couple ideas for you would be to grab the constant 12volt wire coming off of your lighter socket. Atleast then its not a fire hazard. By the way judging by your diagram you have the led's wired in series, I'd check the install instructions again to see whether or not they should be ran in series or parallel just to be on the safe side.
It's not a fire hazard. If you do it PROPERLY it isn't. Use an add-a-circuit or add-a-fuse off of the glovebox to do it properly.
http://www.cardomain.com/id/lanman31337
Sponsored by:
JLCaudio.net
If at all possible you should always wire in parallel and not in series in everything.
Wiring in series leaves a single fault point....Christmas tree lights anyone (the older ones at least).
Also your going to experience a voltage drop at each point in the series, no matter how much current you put thru it.
Wire them in parallel and be done with it
make the top power and the bottom ground, or vice versa.
So you only need 2 points; one for power, and one for ground.
-Chris
Thanks for the info guys. I do have resistors wire in I just did not draw them in on the diagram.
I only have 4 LED's in a series. I put four in a series becasue I copied the way Lunar accent's wired theirs.
Should I change this or will this be ok?
You should be fine as long as all connections are nice and tight. Hopefully you're not putting too much current through them, but without spec of the LED's, I can't tell you.
