my HVAC wont change vents why???? - Audio & Electronics Forum
Thursday, October 27, 2005 7:34 PM
as that title says. I have ac and heat but it will only come out the front. I think its a linkinage. I couldnt find anything specificaly related. any way figured I ask
"boobs now with Riboflabin"
Re: my HVAC wont change vents why????
Friday, October 28, 2005 7:33 AM
Take your hvac panel out and see if anything's disconnected.
http://www.cardomain.com/id/lanman31337
Sponsored by:
JLCaudio.net
Friday, October 28, 2005 8:12 AM
Ill give thata try I still think it's some linkage up near the top vent.
Sunday, October 30, 2005 8:07 PM
Mine did the same thing and the dealer replaced the linkage under warranty. By the way it sounds, it is the linkage. Not sure how to fix it though, like I said it was covered under warranty.
Monday, October 31, 2005 1:48 PM
could also be a vacuum line
Monday, October 31, 2005 1:53 PM
sounds to me as either vacumn lines came unplugged or bad one or a few, check them you should hear a air leak if there disconected though
Tuesday, November 01, 2005 5:10 PM
hmmm il listen for any leaks but its so hard to get to under all the crap evan after you get the dash off you still have a @!#$ load of stuff to get off.
Tuesday, November 01, 2005 5:29 PM
I don't think your car uses a vac line.....this was a common problem on 02+ yrs. What happens is due to the poor design of the linkage cable route it gets bent or disconnected. The cure, simply bend it back into place or worse case scenario change the linkage cable. But diffenitly take it to the dealer to have their asses repair it.
Wednesday, November 02, 2005 4:45 PM
Markseco wrote:I don't think your car uses a vac line.....this was a common problem on 02+ yrs. What happens is due to the poor design of the linkage cable route it gets bent or disconnected. The cure, simply bend it back into place or worse case scenario change the linkage cable. But diffenitly take it to the dealer to have their asses repair it.
I have an 02+ cav. ethier way Im going to the dealr
Thursday, November 03, 2005 2:46 PM
i had the linkage in mine screw up as well. dealer fixed it, but then the little piece of foam that moves to direct the airflow (center of your dash, below the defrost area) go stuck in one spot, so it would not move to change the airflow to the desired location
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Thursday, November 03, 2005 5:49 PM
that happened to you too!! here i thought the mechanic did it to me to be an @!#$ because i cussed him out for putting the dash pad on my roof, with the metal clips facing down, so it scratched my paint
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Saturday, November 05, 2005 6:15 PM
my vents are not blowing out alot of air
I have checked all connections etc... all vents / air flow things are moving as they should be and nothing is blocking the fan (blower motor)
What do you guys think?
Monday, November 07, 2005 7:53 AM
yeah common problem, mine does it as well
Friday, May 04, 2007 5:29 AM
there is a TSB on this for these model years, the mode flapper door foam is jamming its operation, you might be able to pull the ductwork off to expose the flapper door and trim some of the foam off the edges to free it up. My car is a 2k so still uses vacuum actuators, and the linkage on my flapper door broke, so replacement time! (Pull-a-Part, here I come)
Friday, May 04, 2007 10:15 PM
i got an 04 and when i first got it it only blew air out the front. Well i went under the dash and looked behind the control...the linkage was bent out of shape. I unsnapped it, straightened it out and put it back on and i was back in business!! you prolly have the same problem and you dont have to pull the dash apart for this
