well i stated in another post that i hit a deer wed. night, anyways now only my dims work, and whenever i flick to brights the headlights shut off, and no matter what setting i have it on the bright light icon on my dash stays on.
so what im asking is there some sort of relay and could be screwing this up, maybe broken or dirty or something?
Check your fuses and you might have a relay under the dash which is called a high beam switch I would check that first and go from there. The projector headlights usually arent as good with stock bulbs as apposed to doing a HID setup with them. something else you might wanna look into I hope this helps!
ill have to check the fuses, but the brights didnt work when i had stock headlights in, because i had to just set the lights in place because i drove my car home that way at night
