I need help! I have an 05 sunfire and I live in an area with now streetlights(read rural) and I want the lowbeams to stay on when I turn on my highbeams. Does anybody know how to do this?
Dont it will overheat and melt your headlight housing.
There IS a way though, but I dont know it.
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
somebody on ecotecpower.com told me that, but I have seperate bulbs for each beam.
the 03-05 sunfires have seperate beams
it is possible to do
its similar to that
i know in the earlier cavs it had to be done near the switch to make it work right
I like this Idea... highs+low+fogs, it would make up for the fact that they don't make silverstars for our cars. But I wonder if this would cause to much stress on the electrical system... Hmmm...
My Sunfire
Upgrade your wiring first. You'll roast that stock wiring. Or get HID's.
thats actually why I want to do it, I want HID, bad, but can't afford it right now. but my original question still has not been aswered, how do I do keep my lowbeams on when I turn my highbeams on?
My guess would be to get a couple of relays and take a more potent power source. In wiring the relays, you could hook them up so the low beam still gets a power signal when the highs are on. If you don't know much about wiring, DON'T do it yourself, it would be so easy to fry your wiring... But I know I've seen a "Highs + Fogs" how to somewhere..
My Sunfire
HIDs for my lows, and silverstar halogens for my high beams on at the same time is like having a big chunk of day light in front of me. Too bad my high beams were that good just by themselves.
i appologize for using a psot to say this but im at work and outside e mail is strictly forbidden....5secondrule: where in the christ is Alna, Maine? i noticed the Maine plate so i checked ur registry, E-Mail me at JLAudioCavalier@AOL.com if u see this, and as for the high beam+low beam question...if its SAFELY possible with dual bulb systems, thats cool, and wouldnt be a bad mod, if someone could make it work 100% safe and reliable!
i had lots of toys when i was young.slinky,etc.but once i found my penis,that was all she wrote
I'm assuming you could hook it up so that you had a relay, with the high beam power wire being the trigger.....on the end of that trigger is a wire that taps into the low beam power wire. Then ground out as neccessary. If relay's need grounding.
Knowing that relays are basically electronic switches, I think that might work. I have been thinking about it for sometime, and there have been many posts made on this topic. It is just a matter of time before I go out to my car and do it. But please feel free to correct my theory if I am wrong.
Go Premium, it builds character!
1Bad02Cav wrote:i appologize for using a psot to say this but im at work and outside e mail is strictly forbidden....5secondrule: where in the christ is Alna, Maine? i noticed the Maine plate so i checked ur registry, E-Mail me at JLAudioCavalier@AOL.com if u see this,
Holy SHI* someone else in MAINE! I thought I was alone up here
I sent u an e-mail.
My Sunfire
