Alarm system installation - Audio & Electronics Forum
Monday, October 17, 2005 1:43 PM
Anyone know where I could get a wiring diagram for a 1996 Cavalier? I want to install my alarm system myself, and I have the wiring guide for my alarm, but I don't know where to connect those wires on my car.
Re: Alarm system installation
Monday, October 17, 2005 6:35 PM
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Must Use for Remote Start
Accessory Orange Ignition Switch Harness
Tach White Coil
Brake Switch White Brake Switch
Trunk Release Black/White (+) OEM Keyless Module in Trunk
Trunk Pin Black (+) Light in Trunk
Parking Lights Brown (+) Driver's Kick Panel Main Harness
Head Lamp Dark Blue (LO) Pink (HI) at Head Light Switch
Door Trigger White (-) Courtesy Light under Dash
Door Lock Light Blue Driver's Kick Panel Reverse Polarity
Door Unlock White Passenger's Switch is Master Switch
Horn Wire Black (-) Steering Column
Test every wire, dont not assume this is 100% correct...always TEST EVERY WIRE!!!
Monday, October 17, 2005 8:45 PM
where did you find that?
i wanted to know for my 02
wait for it... wait for it... NOW GO!! ---> '02 LS Sport <---
Yahoo IM : buzz122 AIM : buzz122cav
Tuesday, October 18, 2005 5:02 PM
I've seen the same thing posted many times over many years here on the forums... not hard to find
There's also www.the12volt.com which is a good source for installer info.
Thursday, October 20, 2005 11:07 AM
heres a wiring diagram i got awhile ago when i purchased a car alarm from this site: i think for the most part its correct in which wire is which.
