Ive got a question my stereo just shuts off for no reason (there is a sudden power drop) when it hits usually 25+ on my stereo (sound level) as stated it turns off so i looked found that my 12v (red wire on after-market that plugs into a yellow or orange wire on the cars harness) wire was melted so i replaced all of it as far as i could go. From the after-market harness from my stereo to the cars harness but it still does it not as much but usually around 29+ now. I know its a electrical power issue but my question is can I just by pass the harness and go directly to the battery with a fuse? sorry if what I'm typing is vague. I can explain more specifics if asked also its a 97 fire gt shouldnt make much of a difference
Mike Jones..... Who?
Yes you can, but it if i understand this right, you want your deck to be powered off the battery. So if you do that, it will always be on. even when the car is off.
http://members.rankmyride.com/djtorello
if its the constant 12V, then u can run it direct to the battery with a fuse in line withouth noticing anything, if its the switched wire thats causing problems, then u can still run the wire to tha battery; only drawback being your stereo will remain on all the time. You could use a relay tied into another accessory thats on when your car is, but that is more work.
1996 Chevrolet Cavalier SOLD | 2002 BMW 330i SOLD | 2004 BMW 645i
