Cd Player dimmer wire - Audio & Electronics Forum
Friday, October 07, 2005 10:26 PM
i'm trying to install my stock Cd player from my 96 cavalier into my Astro Van, i got it working, but i dont know what wire is for the button lights, also, i have it hooked up so the radio turns off when i turn the key off, But, when i turn the key off, the clock resets. Does anyone know what colour is the wire for the light, which wire needs constant 12 volt power, and which wire is hooked up to the key, thanks
Re: Cd Player dimmer wire
Friday, October 07, 2005 11:06 PM
ummmm...i think you have to hook the red wire to a 12v source....like the ignition fuse on the drivers side...
CaviFL45
Friday, October 07, 2005 11:50 PM
^ incorrect
on the radio side (not the car side), red is for switched 12v (when u turn on and off the car), yellow is for constant 12v (hot at all times), and the orange or orange/white should be the dimmer.
Saturday, October 08, 2005 1:46 PM
^you are also wrong
the stock wires for a 96 cavy are as follows.
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Saturday, October 08, 2005 2:34 PM
^ yes, you are right, those are the colors for the car. read my first four words.
Saturday, October 08, 2005 8:20 PM
ooopsss...my bad I was talking about 03+ harness...totally diff
CaviFL45
