well my Ebrake AND ABS lights are always on.. would one be causing the other?.. ect i hooked it up to a tech 2 it doesnt read any codes is there a way to tun the lights off with a tech 2?.. or what other suggestions do you guys have.. i know the abs on cavs messes up sometimes but why the ebrake too and WHY all at the same time??
How many threads on the same problem do you start?
If those lights came on as a result of your cutting the passlock wires.... then reconnect them.
No, there is no way to turn off the lights with a Tech 2. Codes aren't set for those lights to come on... (that's the Check Engine light... it indicates a code being set).
i connected the passlock wires.. the teft light went away but i still got the abs and park brake..
