12v constant problem - Audio & Electronics Forum
Tuesday, September 06, 2005 12:59 PM
I put in a new deck on the weekend, and after discovering my 12v constant wire going to my deck was ..well, not giving me 12v constantly. I then tapped into the next logical 12v constant source, which I figured was to the cigarette lighter (which I dont use anyway). Now my battery is half dead every time I go to start it. Where I get confused is, would a 12v constant be the same as the next 12v constant? or what should I be tapping into if no the cigarette lighter? Thanks in advance..
Re: 12v constant problem
Tuesday, September 06, 2005 1:00 PM
if all else fails..just run a fused wire straight to the battery from the headunit
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, September 06, 2005 1:05 PM
Do you have your ACC wire hooked up to a constant source by accident?
Tuesday, September 06, 2005 1:14 PM
Might sound kinda dumb- but I used to get confused back in the day..
Wires from radio:
Yellow- Constant
Red- Ignition
Like mentioned above, you sure you are using the right wires?
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
Saturday, September 17, 2005 8:23 AM
well, turns out my battery was shot.
like...10.65 V shot..
it was just a wikkid coincidence that it went at the same time..
new battery = problem solved.
thanks for you're help though!
