450RMS - 2 amps, 8ga enough from batt. to dis blk - Audio & Electronics Forum
Wednesday, September 07, 2005 7:00 PM
Tried to fit everything in the title
I got a Pioneer X952 300RMS and a Lightning Audio Bolt B2.150.2 amp, pushing 150 RMS. I currently have 8ga going to the Lightning amp. Should I upgrade to 4ga to the dist. block and from it to the amp in 8ga?
Last Q: Are Stinger's Nitro good enough? Or should I go with the blue - and more expensive - ones?
Thanks!
Cheers,
G
Re: 450RMS - 2 amps, 8ga enough from batt. to dis
Wednesday, September 07, 2005 7:31 PM
8awg is good up to about 500 watts. any more then 50 amps of current draw and you need to upgrade to 4awg.
i would go ahead and use 4 awg personally...but if you got 8awg ran already then you should be ok
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Wednesday, September 07, 2005 8:53 PM
Overkill now to 4 gauge. You'll upgrade in the future to larger amps
<img src="http://www.webgraffiti.it/gif/smile12/smile197.gif"></img>
