Subs dont turn on sometimes - Audio & Electronics Forum
Sunday, August 28, 2005 12:47 PM
Im running my subs and amp off a stock deck, so my remote is simply a toggle switch with 12 volts behind it.
Sometimes, when I turn it on, Ill get the first half of a bass drop, then the amp will shut off. If I turn my switch off, and on again, it will work.
This happens like 50% of the time. And sometimes can happen 2 or 3 times in a row.
All connections and fuses are ok.
Any ideas?
Its a Kenwood amp.
You're reading my line-break, you are a loser.
Re: Subs dont turn on sometimes
Sunday, August 28, 2005 1:43 PM
Sounds to me like the constant 12V isn't getting enough power when the bass hits. What you can do, is run that remote turn on wire to the Fuse Box (make sure it turns on with the key, then off with the key). I did this with my XM Radio, just used the windshield wiper fuse and it works great.
Sunday, August 28, 2005 4:38 PM
^^ But I dont want the subs on ALL the time my car is only... only when i want loud music, hence the toggle switch.
Monday, August 29, 2005 1:02 AM
then turn the volume down?
SO EVERYTHING!
Monday, August 29, 2005 6:35 AM
Maybe your toggle switch is dying? Mine did that with my underbody kit. It would be on for a while, then shut off. I bought a new switch and that did the trick.
