Installing alarm in '93 Cavalier - Audio & Electronics Forum
Wednesday, August 24, 2005 11:48 AM
Hi,
I'm going to attempt installing an alarm in a '93 Chevy Cavalier 2-door coupe. This vehicle has never had any previous security system work done before. I know nothing about Cavaliers other than what engine this one has.
How difficult is it to install an alarm in one of them?
It would be great if I can get links to locations and diagrams of the necessary wires for this install, such as the door pins, brake light, side marker, ignition, and horn.
Thanks in advance.
Re: Installing alarm in '93 Cavalier
Wednesday, August 24, 2005 11:53 AM
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach White In Harness Behind Engine
Neutral Safety Wire Orange/Black Gear Select Switch
Brake Switch White Brake Switch
Trunk Release Black Switch
Trunk Pin Black/Orange (-) Gate Ajar Switch (Wagon only)
Parking Lights Brown Light Switch
Head Lamp Tan (Low Beam) Green (Hi Beam (+)Head Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Driver's Kick Panel
Door Unlock Black Positive Trigger
Horn Wire Black (-) Steering Column
Windows Up LF=Blue, RF=Blue/White,
Windows Down LF=Brown, RF=Tan
Sponsored by:
JLCaudio.net
